O2 Eliminator ???
Discussion in 'Mods, Upgrades, Accessories and Products' started by Blackness, Jan 22, 2015.
  1. Blackness
    Blackness Active Member
    Hi All..
    My PCV arrived today and I've just been sitting here having a cup of tea and rifling through the box and theres a page here that says about an O2 eliminator doobie ! Do i need one of them too or is recommended etc ?
    Cheers guys
  2. Blackness
    And what does one look like ? I got it from demon tweeks and the ad says "Including required o2 eliminator"... Am i being thick here or am i missing something :(
  3. garyauk
    garyauk Active Member
    An O2 eliminator is basically and connection plug with a built in resistor. You unplug your Lambda sensor (O2 Sensor) and connect the eliminator. This is to fool the ECU that the Lambda sensor is still fitted and hence will not put the engine management light on
  4. Blackness
    Right, so its a separate item to the actual PC ! I don't have one in the pack in that case.. I'll have to give Andy a call in the morning.
    I take it i do need one !? Is it best to completely remove the lambda sensor and plug the hole in the zorst ?
  5. ninja
    ninja Active Member
    Your PCV wont work properly without an O2 eliminator.
    I just unplugged the connector on my O2 sensor cable and taped it out of the way. You can remove the sensor itself from the exhaust if you have the correct bt to plug the hole.
    If you bought the PCV in the UK for a UK bike, you should have got an eliminator with it I think.
  6. Barstewardsquad
    Pretty sure mine is the bit that looks like a blanking plug. Looks something like this but is all white.
  7. RepsolPaul
    RepsolPaul Well-Known Member
    Yes you will need it as it makes the ECU see's the same constant value so it doesn't self adjust to the AFR the lamda sees.
    It plugs in on the left, inside of the frame above where the gear shift rod is.
  8. Blackness
    Lovely, cheers guys, i'll get one sorted in the morning !
    The Lambda sensor lead goes to a socket on the right side behind the fairing Paul !?
  9. Barstewardsquad
    On my RR7 it is behind the right hand fairing on a strip with a couple of other plugs, one of which is the rear brake light I believe.
  10. RepsolPaul
    Yes, sorry, I'm thinking yours is a 08 onwards like mine. Doh
  11. Black
    Black Active Member
    I've an 05 and it doesn't need one. Not sure if this helps or not.
  12. Mr OCD
    Mr OCD Well-Known Member
    You need one. The 08 > blade uses closed loop lambda up to 4k rpm ... So without it you can't control the fueling properly under 4k rpm ...
    Ask me how I know ... ;)
  13. Blackness
    Mine does need one and I've been onto Andy at Demon Tweeks and he was suppose to get it sorted and call me back but he is always a bit slow at the "getting back" bit... Next problem is i use a mac book and Dynojet only seems to work with a PC, so making another hassle getting a map on it before i get to the dyno for setting up ! Anyone know a way of doing it with a mac ?
    Also, anyone seen anywhere doing blanking bolts to fill where the lambda was ?
  14. Womblewizard
    Womblewizard Active Member
    Wouldn't worry about blanking the Lambda sensor just tape up the connector and cable tie out the way, can't be seen. As for maps I also had this problem just borrowed my mates Pc takes 10 mins tops!
  15. Blackness
    I figure that while I'm there i might swell totally remove it and it can't hurt for a bit better exhaust flow !
    Can i map the unit before its all installed on the bike ?
  16. Womblewizard
    Yes mate I did! But once fitted did plug mates laptop in just to to see the rev counter go up and down on the screen..........So cool!
  17. Black
    Black Active Member
    So out of interest which blades need this eliminator and which don't?
  18. Gilesy
    Gilesy Elite Member
    2nd from right.. my O2 (green loop wire) right hand side of the bike . Ignore the tie wraps.. HM GP Shifter was plugged in
  19. Gilesy
    Gilesy Elite Member
    only need this if you have fitted a PowerCommander..
  20. Black
    Black Active Member
    Must admit I fitted mine with Yoshimura and PC back in 2005 and never fitted the eliminator. Ran on the dyno with great results and still running sweet as a nut now. Ignorance is bliss possibly! Lol
