O2 sensor on exhaust
Discussion in 'General 1000RR Discussion' started by blade1980, May 2, 2011.
  1. blade1980
    blade1980 Active Member
    Hi, i'm about to order a yoshi r77 exhaust for my 2010 blade, does any one know if this come with a point to put the sensor into or if not what do i do with it!!
  2. garyauk
    garyauk Active Member
    I wondered the same thing so I emailed Yoshi R&D and they said some models do and some don't (helpful I know) they asked for the part No and they would tell me. But as I am still waiting for it (9 weeks now) I couldn't tell them. You will be better off running it with an O2 eliminator and PC anyway. If mine turns up with the hole for the O2 sensor I will just put a blank in it.
  3. JM1
    JM1 Active Member
    If the exhaust doesn't come with a bung you could get one welded in.
    Or, if not, you can just zip tie the sensor cable out of the way - the bike will almost certainly run fine.
    (I have a PCV & O2 sensor eliminator myself though).
  4. dan.1moore1
  5. dan.1moore1
  6. nigelrb
    Six and a half years later, I revitalise this thread!!
    I have the O2 sensor in Yoshi R77 S-bend pipe, and it's actively wired to somewhere/something.
    I can't find reference to its function in the Yoshi or Blade 08-11 service Manual. Could one of the engine gurus please give me the lowdown on its function? I have no performance issues - this is purely for knowledge. Cheers!!
  7. Lozzy
    Nigel.....it's Boxing day.......ET's on't telly...go & open a can of beer & stop wondering about yoshi functions :p :D
  8. nigelrb
    Damn. And I thought you'd be off cooking dinner now!! Guess I'll come back later when a REAL guru can reply!!:D:D
  9. nigelrb
    Bumped because Lozzy said ET's on telly. Can anyone answer what the O2 sensor actually does?
  10. levin
    levin Active Member
    It tells the ecu what the air/fuel mixture is , so it can run properly , but when fitting a power commander or the like it gets blanked off caus it would be conflicting with the set map %
  11. nigelrb
    Thanks very much for that, Levin. This only came about when I was doing some serious 'undercarriage' cleaning and noticed the nodule and wire on the exhaust before the end can. I don't have Power Commander and will not be doing mods that require it. Cheers again!
