Odd Charging Problem
Discussion in 'Maintenance' started by mattmk1, Mar 17, 2016.
  1. mattmk1
    mattmk1 Active Member
    I was expecting the voltage to be a little more stable? Although im more used to cars than bikes.
    I also thought anything over 15V was basically overcharging??
  2. sulaco
    sulaco Active Member
    Haynes manual states 15.5v@5000rpm
    My voltage changes are almost the same as yours but about 0.5v higher across the board, but I have a brand new battery, stator and reg/rec.
    At idle putting the indicators, lights, horn etc will make it dip.
    unless you're exceeding 15.5v I'd see how it goes.
  3. mattmk1
    OK thanks, iv just run it up to 95 degrees and took the following:
    13.2 battery cold
    14.8 cold fast idle
    12.8 hot idle
    12.6 hot idle main beam on
    2k rpm 14.1 v
    5k rpm 14.7 v
    Hot resistance
    0.5 through the reg rec where it needs to be.
    I can't decide if I'm being paranoid or not Haha. Seeing the idle voltage is a little worrying but it's steady and jumps the second you touch the throttle.
    None of the wiring or plugs are getting hot.
  4. sulaco
    If it were me I'd be happy with that.
  5. mattmk1
    Cheers mate :)
    I put it back together, took her for a run jut now, all seems fine.
    15 miles and all was forgiven haha
  6. Mike07
    Mike07 Active Member
  7. Mike07
    Is all okay,?..... keep an eye on your battery for a short while.... make sure its not cooking, you should be good.
    Mike.
  8. mattmk1
    Yep all appears good thanks!
    All connections cool, battery cool, no acid smell, no bump starts. Ill check it all again in a few weeks as service is due so ill dig out the multimeter.
