OEM exhaust painting
Discussion in 'Maintenance' started by bonjo, Jul 22, 2020.
  1. bonjo
    bonjo Active Member
    As those who have them know RR08~15(?) silencer paint and finish was pathetic and very non honda like.
    Black paint discolouring, flaking and the steel under it developping surface rust.
    I am looking at having the original paint removed and then repaint the silencer.
    Has anyone gone down this path?
    Sand, glass, bead .. blasting?
    Ceraminc, high temp coating?
    Or DIY?
    :confused:
  2. PauloHRC
    PauloHRC Elite Member
    I did it on my '09. Removed the exhaust and then the heat shield/end cap or what ever you want to call it. Gave it a good clean up and removed any rust, it wasn't very bad to be fair. I bought some black heat resistant exhaust paint from a local car shop, you know the type.....little independent business that seem to have everything at a good low price. Anyway gave it two or three coats of that and it looked like new. :)
    Not sure it's worth going to any great lengths as you don't see most of the exhaust, it's all hidden by the heat shield. If it's really bad I'd just buy another one. You can pick them up really cheap on eBay.;)
  3. bonjo
    bonjo Active Member
    The surface rust is mostly on the inside (out of sight).
    So no primer, straight on with the paint?
    How long has your handywork lasted?:)
  4. edderby
    edderby Active Member
    I used fine wet and dry paper, then sprayed with Hammerite high temperature matt black paint from Halfords. No primer, looks great. I did it about 2 months ago and still looks perfect.
  5. PauloHRC
    Nah.... No primer, its matt black anyway so just give it a few coats! I've not got the bike anymore so can't comment on how long it lasted but its a dead easy job if it needs doing again in a couple of years ;)
  6. bonjo
    bonjo Active Member
    Thanks guys. Just a quick recap on removing the silencer:
    detach the valve cable from the motor under the seat right?
    How can I avoid the engine check light from coming on when I re install the silencer?
    Any do’s or don’t’s
  7. PauloHRC
    When you remove the cable from the servo wheel......you'll need to turn it slightly to give the cable a bit of slack. When you reconnect it all after you've finished, make sure you turn the wheel back to its original position, that will eliminate the error light on the dash. ;)
  8. edderby
    Don't reconnect the servo cable! The bike will be nicely louder at low revs and run fine. If you don't like the result then reconnect it. Mine's been disconnected for about 10 years now...
  9. PauloHRC
    This is true, in fact I didn't reconnect the cable as it is well known as the exhaust flapper mod. However you must still return the wheel to its start position to make sure the light doesn't appear on the dash!p
  10. bonjo
    bonjo Active Member
    thanks a lot.
    So I will mark the wheel start position before slackening the cable. And then reposition if aftewards.
    It sounds like without the cable connected, the valve is open (opening the 2nd chamber) if so, I might try leaving it disconnected to see how it is:)
  11. Slick
    Slick Elite Member
    Went the DIY route too, removed loose rust and paint using a wire wheel, degrease, alcohol spray.
    layer of kurust, bake, High temp paint with brush , bake, one final layer, bake. Only used twice in the dry since so cant comment on longevity!
  12. bonjo
    bonjo Active Member
    I have stated looking at ceramic coating which appears to be the most suitable finish for exhaust (as per the claims!). It is 80~100£ but if the claim is true, worth it.
    This excercise is not because I am selling the bike but keep it in good nick as the OEM silencer is xtremely expensive and non OEM getting rarer because of the bikes age.
  13. edderby
    Yes, always do this and you'll have no problems.
  14. PauloHRC
    There is also a little tip that I haven't taken advantage of but keep meaning to do it as ive got an Arrow can on my SP.
    Secure an elastic band to the servo motor and around the wheel and this puts tension on the wheel and prevents it from over rotating and burning out...... Makes sense I suppose. ;)
  15. Kentblade
    Kentblade Elite Member
    That’s interesting, someone enquired about the condition of the OEM one I am selling then said they needed to get a price to powder coat it, I was a bit dubious if the finish would last.
  16. bonjo
    bonjo Active Member
    might have been me if it were on ebay:). I since found out powder coating is totally unsuitable for this because of the heat!
    My aim is to use my own silencer if the visual surface rust on the inside is of no concern.
  17. Kentblade
    If seller sent extra pics, then yep probably was me :)
