Ohlins FGRT813 Forks with SP Brembos
Discussion in 'Mods, Upgrades, Accessories and Products' started by TW4T50N, Jan 3, 2017.
  1. TW4T50N
    TW4T50N Active Member
    So about a year ago I bought a set of SP Brembo monoblocks and just been offered a set of Ohlins forks for the bike.
    Does anyone know if the SP Brembos are a straight fit onto the FGRT813 forks? Do they need a spacer? Or simply don't fit at all?
  2. sps170373
    If the SP brembo match the diamensions of the m4's they should fit straight on with no spacer needed!
  3. TW4T50N
    Believe the SPs require a small doweling on their forks, going by the microfiche for the front brakes. Think the M4s require no spacer? I've seen a set of M4s mounted to the 813s as that's what the fella did that owns them currently, leading me to believe the SPs fit (hopefully..!)
    From what I've read (somewhere on here, too), the 813s are machined without the spacer dimensions so fit any caliper (with/without spacers). The 12+ FGRTs were machined with the spacer dimensions so a little more tricky to get calipers to fit.
  4. si1000repsol
    I have the FGRT813's and the M4's were a straight fit without spacers.
  5. Dave dunlop
    Dave dunlop Elite Member
    What model Ohlins did they fit on the SP? Were they 813's?
  6. TW4T50N
    The 813s were 08-11, SP was 14 onwards?
    Not sure what model but don't think they are 204s as they require no spacer and the microfiche for the SP has dowelings.
  7. sps170373
    813 were full adjustment ohlins for 08-11 m4 brembo fit with no spacer!
    204 are full adjustment ohlins for 12-16 but brembo m4 won't fit unless machined away 5mm but standard calipers fit fine
    Sp ohlins are just that for SP but don't have the range of adjustment the 813 and 204's have hence why some people have put the 30mm nix kit in them
