Hi Not removed the panels from my 15 plate blade yet - needed to do an oil change.. does the bottom panel just come off, or do i need to take any others off as well. Thanks
Belly pan off. Right side panel just undo the rear most bolt to allow the panel to be pulled out slightly to access oil filter easier.
