oil change
Discussion in 'Maintenance' started by liquidcooled1966, May 2, 2015.
  1. liquidcooled1966
    liquidcooled1966 New Member
    hi all...I have just bought a 2007 blade with 116 miles from new. I have rode the bike to the mot station and back approx. 5 miles at a very gentle pace.
    the bike has been off the road for the last 7 years but was stored in a heated garage.
    I am just wondering if I need to get the oil and filter changed now, or wait till the mileage is at service intervals and use the braking in oil. any advice would be appreciated. best regards
  2. Barstewardsquad
    Change the oil, filter, brake and clutch fluid, and then change the tyres as well. Would also consider changing the coolant as well.
    • Agree Agree x 3
  3. RRoss
    RRoss Active Member
    Yup,if the bikes been sitting all this time change all the fluids and filters. Check air filter too just in case something's crawled in there.
  4. liquidcooled1966
    yes I thought so have booked the bike in but couldn't book it in for 3 weeks, so wont ride the bike till I get it sorted.
  5. Barstewardsquad
    Good point about the Air Filter, I forgot that bit.
  6. liquidcooled1966
    will get them to check that thank you. not sure on the tyres they seem fine, mot fella never said anything but will get the dealer to check them.
  7. Repsol Rob
    Repsol Rob Elite Member
    What a waste........ but I bet in pristine condition ???...............never mind oil change.....a warm soapy rub and a good ride will sort her out !!!!! :D
  8. Gilesy
    Gilesy Elite Member
    How exciting! It's a new bike! I would also stick a new chain on in case of and tight links etc from sitting.
  9. Barstewardsquad
    Tyres may look OK but if they have been on the floor and haven't turned in 7 years then personally I wouldn't trust them. If nothing else tyres have improved in the past 7 years ;)
  10. N1xxl
    N1xxl Member
    Would take you a couple of hours to do all comments yourself and nothing technical if you've soft and gentle hands and good experience gained too. Get the manual out and DIY.
  11. liquidcooled1966
    when you have nine bikes 3 with delivery miles only it makes sense. he also had a fireblade 1000 repsol on a 11 plate.
    the bike was on paddock stands for the past 7 years or so, so I assumed they would be ok. I don't want to get any scratches or mess with any of the wheel bolts axles etc. they bike is as new there is not a mark on it everything is shiny as it left the showroom its in perfect condition. he also purchased the factory cover, u lock and single seat cowl all still wrapped up in there original boxes. I have never seen anything like it unless it was a superbike which he has. he had 9 bikes in total including the one I bought. he has 3 top of the range ducatis which have all got delivery miles on them bought new. he has a 2011 repsol 1000 and a Suzuki 750 04 I think which are his runabouts. an early r1 with 1800 miles on it bought new and a 998r which he also uses. he was a dream to buy off, everything was with the bike inc all the paperwork from new 7 sorn certificates etc.
    the chain still has the original white grease I have turned the wheel and it all sits fine, may just want slight adjustment.
