Oil change.
Discussion in 'Maintenance' started by Great Guy, Aug 28, 2015.
  1. Great Guy
    Great Guy Well-Known Member
    About to change the oil on my blade. Is it wise to warm the engine up before draining the oil.
    Also, is it ok to run the engine a little with the sump nut removed, so as to "pump" out any remaining oil? Thanks.
  2. Jamiestrada
    Just run for five mins let sit for two or so mins then remove the sump plug, no need to turn it over at all ;)
  3. red5
    red5 Well-Known Member
    FFS I hope your joking!!!!!!!,DO NOT RUN THE ENGINE WITH THE SUMP PLUG REMOVED.
    • Agree Agree x 3
  4. exuptoy
    exuptoy Elite Member
    :D
    Can't believe that was a serious question.
  5. Great Guy
    I can't believe you can't believe it was a serious question. We use to do with cars years ago.
  6. exuptoy
    Ok. Fair enough.
  7. ShinySideUp
    ShinySideUp Elite Member
    Yeah but they also thought asbestos was a miracle product back then! :D
    • Funny Funny x 4
  8. thezipsteruk
    thezipsteruk Elite Member
    Can you do it please.
    I have a vision of a reverse oil volcano?? lol
  9. Stevie_d
    Stevie_d Senior Member
    Your only warming the engine up to make the oil thinner, so it drains out better. I've only ever done that with a car and a bike. Never heard of actually running the engine with the sump/drain plug removed
  10. Stevie_d
    @Great Guy u bought a lift for the bike yet ?
  11. Great Guy
    Not yet.
  12. Nigelg79
    Nigelg79 Active Member
    Probably already dropped the oil out I know my but advice for next time, for what it's worth.
    First off, never run the engine without oil or while draining.
    You don't necessarily have to warm the engine before draining the oil. It does make it thinner but...
    If the engine hasn't been warmed for a while the oil will be thicker, yes, but it will have also all drained into the sump or southern most areas of the engine already, meaning you won't need to wait so long for it to drain through all the other engine bits. And when I say thicker, it's hardly thick in the first place and due to the fact it's oil, it's pretty slippy anyway!
    Six and two threes though, as long as you leave the bike draining for about 10 minutes using either method it'll be fine.
    Have fun!
    #12 Nigelg79, Aug 30, 2015
  13. Great Guy
    Thanks. Job now done. Used the method you have mentioned, engine warmed up.
