Oil change
Discussion in 'Maintenance' started by rebel, Jan 12, 2016.
  1. rebel
    rebel Active Member
    I was just wondering what most of you do when you change your oil do you do it after you have warmed up the engine or drain when it's cold most people seem to say warm up the engine not really sure of the reason behind that I always do mine with a cold engine
  2. Mr OCD
    Mr OCD Well-Known Member
    I always do it warm as the oil flows better ... but tbh it makes little difference.
  3. Slick
    Slick Elite Member
    warm potentially drains faster but I leave to drain overnight anyway!
    The main thing is too get rid of as much of the old stuff as possible which I think is more dependent on time rather than oil temp.
  4. RR_mike
    RR_mike New Member
    I always drop the oil after i've let it warm up for a few minutes, drains quicker and everything tends to flow a bit more. Just make sure you let it sit until there are no more drops coming out, can take a little while.
  5. dansp1
    dansp1 Active Member
    Lay the bike over as far as you can on each side, drains out of all the nooks and crannies then, best done hot because it flows much better
  6. ccr32
    ccr32 Active Member
    Same here.
  7. sp1n99
    sp1n99 Active Member
    It's also about getting any contaminates suspended in the oil before draining rather than sitting in the bottom of the sump.
  8. Nigelg79
    Nigelg79 Active Member
    If doing hot just remember to leave to drain for a while as some will need to come from the top of the engine and work its way down.
  9. jc6830
    jc6830 Active Member
    As above, draining when hot is best as you get all the contaminants suspended in the oil, rather than sat on the bottom of the sump. Best done after a ride and left to drain overnight. Crack the filler cap before dropping and it'll not glug as much. Wear a pair of marigolds to save scalding and staining yourself.
    treat it to a new drain plug washer (oem is alloy, not copper)
    and the oem filter requires a 14 flute 65mm wrench, most motor factors will supply for half the price of honda.
  10. bonjo
    bonjo Active Member
    when hot, oil is more runny and carries more undesirables before they have had time to settle. So this is the best time to do it. But also the longer you let it drain, the better
  11. sulaco
    sulaco Active Member
  12. Autopilot
    Autopilot Active Member
    Sorry for being a bit ignorant, would copper washer be bad ?
  13. SteB
    SteB Member
    Copper washer would not be bad, the washer just has to be made from something softer than the plug and casing so it deforms and seals, and also capable of withstanding the temperature. Copper is more expensive than most soft alloys nowadays hence the move towards alloy sump plug washers by the OEMs.
    Stay away from the O-Ring sump plugs, there are two issues with them.
    1. The 'Special' material that expands in oil is not special at all. It means that the material is not compatible with the oil and is actually absorbing the oil. Eventually the material will decay and some of it will end up in your engine
    2. O-Rings, even in the right material (Viton or Aflas), will suffer compression set, (Hardening of the rubber), and will eventually be so hard that they no longer seal as the engine goes through thermal cycles. Copper/Alloy will expand and contract at a similar rate to the rest of the engine so the load applied to it by tightening the plug remains.
  14. Great Guy
    Great Guy Well-Known Member
    After a ride and leave over night .
  15. BoroRich
    BoroRich Elite Member
    Warm up. Drain for 30 minutes. New washer. Fill her up. Done.
  16. Autopilot
    Many thanks for the comprehensive reply SteB, had ordered some copper washers to do oil change and then saw thread and was worried I should have gone for alloy.
  17. SteB
    SteB Member
    No Probs, I've worked with seals of most types for 19 years now....pays the bills. ;)
  18. sinewave
    Sounds like Fun!
    • Funny Funny x 2
  19. sp1n99
    It's a sea lion but still funny.
  20. Ramsay
    Ramsay Active Member
    I change the oil after warming up the engine and leave to drain overnight. The oil flows better and the oil sludge is removed better.
    I use the Stahlbus drain valve
    http://www.stahlbus.com/info/en/products/oil-drain-valves
    No broken oil drain thread and no scalded fingers any more. Works fine!
