Oil & Filter
Discussion in 'Maintenance' started by RepsolSam, Jan 4, 2015.
  1. RepsolSam
    RepsolSam Well-Known Member
  2. sps170373
    Why do you want 10w40 semi synthetic? when the bike should have 10w30 fully synthetic?
  3. RepsolSam
    Ah...so both not correct? But advertised for a 09 blade?
    Would 10/40 fully synthetic not do?
  4. Tezza H
    Tezza H Active Member
    Be careful asking about oil Sam, I asked the question yesterday and some dude shouted at me, lol
  5. Dave V
    Dave V Elite Member
    I'm no expert on oil so won't share my little knowledge on it in case I miss advise.
    But if the bikes spec'd for 10/30 and it's readily available why would you buy 10/40?
  6. Blackness
    Blackness Active Member
    Honda recommend 10/30 but lots use 10/40 semi as it doesn't burn so much if you have an oil burner ! Both will still protect your engine fine dude ! I use 10/30 fully, my mate uses 10/40 semi... I use a bit more oil but my bike smells sweeter ;) lol
  7. RepsolSam
    apparently my exhaust stinks...friends are not able to ride behind me...maybe oil related...
    so really both oils i listed will do the job.. i know in my car i use a thicker one as it dont smoke as much..
  8. Blackness
    Stinks ! Castrol is a lovely smell... I love the smell of it in the morning ;) lol
    Your bike shouldn't be smoking tho !
  9. RepsolSam
    sorry was talking about my car smoking...Diesel
    Bike smelling, is under acceleration guys can smell it who are following me...
  10. ccr32
    ccr32 Active Member
    I posed the same question to Opie Oils recently, who said the following:
  11. Souleh
    Souleh Active Member
    To really fuck things up.... I use 300v 15w50 and a genuine honda filter. NGK laser iridium sparks.
  12. Kentblade
    Kentblade God Like
    This is one of those can of worms thread where everyone has their own favourite brew.
    In my case after years of Castrol, I have switched to Silkolene Comp4 XP 10/30, night day difference in the gear change, so much smoother, either that or I have learned to use the clutch.
  13. RepsolSam
  14. Souleh
    Is saving 15quid worth knowing you could be using the best oil? Your choice.
  15. Blackness
    Yeah, they do that ! Stick a load of redex in it mate ! Give the injectors a treat.. (The car that is !!!)
