If anyone has any OEM hexagon head engine casing bolts for the clutch and generator covers they don't need, could you PM me please. The bike year is 2010 The previous owner had fitted protective engine covers but didn't keep the original bolts.
Hi Matt I've put carbon fibre covers on mine and have the OEM bolts somewhere. Mines a 2010 model too. I think you only need the 3 longer 40mm ones iirc, but let me know which ones you do need and I'll have a look for you? Chin
Hi Chin Thanks for your reply Here's a photo of the bike with the protective engine covers removed. You can see the previous owner has re-used the stainless button head socket screws that came with the aftermarket engine covers and he's put plastic spacers under the heads to make up the space vacated by them. He's done the same thing on the generator cover. Matt
Hi Matt Just went up in the loft to look for them, but couldn't see any. Now I know why! My carbon cover uses different bolt locations to yours, so are still on my bike. Sorry, but hopefully another member may be able to help. Chin
Hi Chin Turns out, all the engine casing screws are the same size and part number, M6 x 28mm flange bolts. Anyway, I was in a hurry to get the bike back together so I bought some from Fowlers. The only ones I could find on Ebay were titanium
