PCV earth location
Discussion in 'Mods, Upgrades, Accessories and Products' started by wedgiewolves#223, Jan 21, 2015.
  1. wedgiewolves#223
    wedgiewolves#223 God Like
    Hi tidying my wiring up on blade and fitting the SS quickshifter . My PCV earth wire is on the negative of the battery which makes the loom quite tight just looked on website and says fit earth the the bank of green engine earths . I have my HM on the starter solenoid earth bolt so dont want to crowd that one . Just wondered if anyone has fitted there had any troubles etc .
    Cheers Lee FIG F
    http://www.powercommander.com/downloads/16-034/install/pcv/eng16-034.06.pdf
    #1 wedgiewolves#223, Jan 21, 2015
  2. Daznorthwest
    Daznorthwest Elite Member
    I put mine on the frame next to the gear position sensor wedge. There's a cluster of about 5 wires on it. Nice and tidy and doesn't strain anything.. So yeah it's where your asking lol.. Had all mine over the years there and no bother pal
  3. Mr OCD
    Mr OCD Well-Known Member
    Mines just connected straight to battery ...
  4. wedgiewolves#223
    Cheers buddy im on the same one now ha ha I knew in my own mind but I like confirmation cheers buddy
  5. wedgiewolves#223
    I did at first but wire seems a bit to tight and seems a lot better on the cluster of earths
  6. Mad Matt
    Earthing points are for little girls, i earth everything to my little toe:D
  7. Mr OCD
    That explains why my earth cable was extended ... :)
  8. Mr OCD
    Proper men earth using their teeth! ;)
  9. sinewave
    Your far better earthing things like Quickshifters and PCV's etc to the main earth bonding point on the chassis.
    Reason being is that generally is a better connection point, usually centrally mounted behind the engine so no probs with wire length and also aliviates the risk of these small leads going un-noticed and not re-connected if the batt Neg wiring is discon at any point for maintenance purposes.
  10. wedgiewolves#223
    Good point J im just useless with wiring ha ha so I wanted to be sure cheers mate Lee
