Possibly braking my top spec blade . I'll know come Sunday night/ Monday if Iam . Please text or ring to register any interest Complete Engine with Head work with HRC cams and adjustable cam sprockets and lobes machined casings with HRC crankcase breather and ali catch tank HRC kit gearbox Hrc velocity stacks Kit head gaskett Samco hoses Gb covers Radiator HRC ECU and loom HRC quick action throttle Brembo RCS master cylinder Brembo span adjuster Brembo res and bracket kit Bazzaz fuel module HM quick shifter plus Ohlins forks Ohlins 30mm kit Over sized magnesium yokes top and bottom GPR 4 steering damper Full akrapovic titanium system Motoholders front subframe Moto holders rear subframe HRC overflow bottles Carbon frame covers Handlebar switch for radiator fan LSL high rise clipons Promach Rearsets Harris quick release fuel caps and tank Ohlins ttx mark 2 rear shock 2015 gold sp Wheels And Galfer discs and endurance captive spacers Hrc captive rear caliper bracket Frame , swingarm and yokes 2015 gold sp spare wheels with captive endurance spacers but with no discs 07706326464
I'm interested in the following: Harris quick release fuel caps and tank ( i take it this is a standard tank - any rust inside ?) Radiator - Is this a larger ( race type) one ? GPR 4 steering damper - does this come with all the brackets etc ? Cheers,
Tank is standard and in good nick ..rad is standard but hooefully be going with the lump and the gpr damper is compete with everything to fit . Cheers
[QUOTE "Moon, post: 399027, member: 2742"]How much for HRC gearbox and clip ons? [/QUOTE] U you'd have to buy the complete lump mate to get the gearbox Clipons 70 ish
