Power Commander V for 2008+ CBR1000rr
Discussion in 'Wanted' started by Alblade, Jun 8, 2013.
  1. Alblade
    Alblade God Like
    Fueling on mine at low revs is lumpy / frustrating in traffic so think it makes sense to put one of these on.
    Will have a look on ebay as know they turn up.
    Anything to look out for / be aware of ? I know it will need to be setup on a dyno to get the best from it.
    Bike has an HM quickshifter but don't think that impacts one - any one got info. on this?
  2. MOz
    MOz New Member
    It doesn't. PCV will fit no problem with an HM. You can get an HM that'll plug into a PCV but it doesn't work as well as the standard spark cut shifter (that you have).
    I have one. It's £8k and it comes free with a 2011 HRC with loads of other bits ;)
  3. jgraham562
    jgraham562 Active Member
    If you check out Ebay for seller called streaker600 he does lots of pcs and equipment too. He's dead easy to deal with and fair too. I got my PC5 off him. He's working away for next 8 days but available via email which you can get off some of his ads. Hope this helps.
  4. thezipsteruk
    thezipsteruk Elite Member
    If you do get and fit one, Id love to know if it does sort out the lo down snatchiness.
    It is my bug bear when used for the daily commute, especially in scuzzy wet conditions.
    Cheers
  5. phantom
    phantom Active Member
    only thing it doesnt do is fix the idle surge
