Power commander
Discussion in 'Wanted' started by Rids666, Mar 25, 2017.
  1. Rids666
    Rids666 Active Member
    Hi all
    After a PCV for a 07 blade if anyone has one going?
    Cheers
  2. brg1000
    brg1000 Active Member
    You know that a PC3 does almost exactly the same job as a PCV. The only difference is the PCV has a 5% throttle group of fuel cells and when does a bike run at 5% throttle. The PCV actually uses PC3 maps. All you will do if you just want fuel control is spend an extra 70 or 80 quid buying a PCV
