Powerline Adapter.
Discussion in 'Non Bike Related' started by Great Guy, Aug 5, 2018.
  1. Great Guy
    Great Guy Well-Known Member
    Just noticed the power link in the hall is not flashing green as per usual. The one upstairs is fine.
    Consequently, I can't get on the internet in my normal fashion. Now on via Wi-Fi. (bt internet).
    Am I correct in thinking the one down stairs is broken? I have had them about 4 years.
    How can one test them? They are ZyXEL HD . Should I just purchase 2 more. The were about £40 so they don't owe me anything. Thanks. Which are the best one?
  2. Iain
    Iain Active Member
    You could have a read of the manual, and try resetting and re-pairing them again. Do it on the same double socket so you can see what each one is doing, and to minimise the risk of one getting paired to one your neighbours might be using!
  3. Great Guy
    Thanks
  4. callumw
    callumw Active Member
    From memory, when you set them up they are paired with one as the Master and the other(s) as slaves.
    If you accidentally switch off the "Master" one then they can all lose their connection.
    Try switching them all off, switch on the master then switch the others on... they should reconnect again fine :)
  5. Great Guy
    Seems a very good idea, will do.
  6. Great Guy
    They are now working again.
