What do you use? It seems my big feet are rubbing the swing arm... not an issue as there is no damage so far but I want to prevent rubbing the paint off... Ideas? (apart from fluffy slippers obviously!)
You can get some clear sticky back vinyl like venturshield.. I apply it to the swingarm where the boots rub plus I put some behind the exhaust.. If you get the air bubbles out you can't really tell
Search for 3m Helicopter tape it's really good stuff I've used it f1 cars when I was in the trade. You will get some of flea bay quite easily.
I'm using lizard skins.Its a anti rub fabric type adhesive tape.Very very strong.Use it on pushbikes. I'm also trying this rubber paint that you spray on and when it looks bad just peel it off.Not tested it yet but in time will let all of you know if its any good.
