Quick action throttle
Discussion in 'General 1000RR Discussion' started by kingy3, May 28, 2019.
  1. kingy3
    kingy3 Active Member
    Does anyone know how difficult it is to fit a domino xm2 quick action throttle to a 2010 blade cheers guys
  2. Liddell98
    Liddell98 Active Member
    It's a little bit awkward trying to get your hand in under the side at the air box but I'm sure you would manage.
    If my memory serves me correct I'm pretty sure you need to take the air box off, I'm sure I had my tank off too but could be wrong.
    The side at the throttle is easy but connecting the other end was tricky and tight trying to see and get your hand inside the frame.
    Let me know how you get on
  3. kingy3
    Thanks mate for the advice I will let you know
  4. Liddell98
    I usually always you tube it first, watch how they do it and then have a go myself, mostly everything is on YouTube these days and it definitely helps.
  5. kingy3
    Ok mate wil do cheers
  6. ninjagogo
    ninjagogo New Member
    i fitted one to my 2010, wasnt hard just awkward, ended up having to take the throttle bodies off to get to the lower cable, but also fitted speedo healer and quickshifter at the same time as with everything out the way it made gettting to coils so much easier, dont think i couldve fitted the cables to the throttle without removing the throttle bodies though.
    • Downvote Downvote x 1
  7. kingy3
    Ok cheers fella thanks for the advice
