R&G Bar End and Aero Crash bung
Discussion in 'Wanted' started by Barstewardsquad, Jul 19, 2014.
  1. Barstewardsquad
    Only need one of each but will buy pair if you have them and don't want to split them.
    Don't think it matters but they are for a 2007.
  2. Muffking
    If your bolt is ok then you could search ebay for a single as there are only 2 types, one with a flat inside edge, and the one we use which reduces to a smaller section with a metal cup over the edge. You can then re use your old inner sleeve if the replacement comes with the wrong bolt size.
  3. Zanshin
    Zanshin Active Member
    You can buy just single items from R&G direct.... they are very helpful.
  4. Barstewardsquad
    All sorted thanks to Andy @ DT and Evotech
