RACEFIT Carbon End Can new
Discussion in 'Parts, Accessories & Clothing' started by jack, Oct 29, 2016.
  1. jack
    jack Active Member
    This end can will fit to any racefit link pipe,.Ideal to replace any scuffed or damaged end.
    £150
    #1 jack, Oct 29, 2016
  2. Bows blade
    Bows blade New Member
    Does it fit straight onto the standard pipe pls???
  3. jack
    jack Active Member
    DON'T KNOW M8
  4. TW4T50N
    TW4T50N Active Member
    That can has been cut mate, missing the link pipe.
  5. jack
    jack Active Member
    This end can will fit any racefit link pipe,has not been cut off. Ideal to replace any scuffed or damaged exhaust.
    To TW4T50N if you do not know it, do not enter the people astray.
  6. TW4T50N
    Hi mate, you can clearly see the rivet hole has been drilled out in one of the photos.
    The pipes come as one item, the link pipe is attached to the end can.
    For your reference: http://store.racefituk.com/collections/honda-cbr1000-rr You'd have to get a link pipe custom made or rework a link pipe from another end can.
  7. TW4T50N
  8. jack
    jack Active Member
    As I said Ideal to replace any scuffed or damaged exhaust.
  9. TW4T50N
    To answer your question: yes it will fit onto standard headers, but you'll need to contact Racefit to get the link pipe as they don't sell these separately.
  10. jack
    jack Active Member
    Oh m8 it is for replace any scuffed or damaged end!!!
    • Dislike Dislike x 1
  11. TW4T50N
    I answered his question because you didn't know the bloody answer.
    Jesus.
  12. jack
    jack Active Member
    If you do not need why u wasting time
  13. TW4T50N
    It's called advice. You don't know about the item you're selling and it stops someone buying an item they are unsure of...
  14. jack
    jack Active Member
    so you are wonderful
  15. Cook
    Cook Active Member
    He's trying to say it'll be ideal for someone who already has this exhaust and needs to replace the sleeve due to damage! It's not a full piece and you would need to speak to racefit if you wanted the link pipe so you could use it as a replacement for a standard can.
  16. TW4T50N
    Which the original listing did not explicitly state, hence the edit yesterday... It also answered the question for the gent who was interested in it ;)
  17. brg1000
    brg1000 Active Member
    Jesus that was epic.... Give you £80 for it if you are interested.
