rear peg brackets
Discussion in 'Wanted' started by Skippy79, Dec 22, 2013.
  1. Skippy79
    Skippy79 Active Member
    I'm looking for a set of those rear pegs replacement brackets
    I found them on ebay for 53£ with another 36£ p&p, which is too expensive for what they are :D
    anyone got a set they don't need anymore or have sold their blade and have them left??
    or anyone want to make them?
    send a pm please if you can help as my computer is stuffed and ain't on here that often at the moment ;)
    thanks
  2. IcarusGreen
    IcarusGreen Elite Member
  3. Skippy79
    yes there the ones, need it to fit a 2012/13, but think that the 08+ fits
  4. sinewave
    Here ya go Skippy, £2 each and articulate so always at the perfect angle!
  5. Skippy79
    no I need it for my exhaust hanger to attach to it when I need another can for the quieter days, otherwise I'll have to be taking the subframe apart every time, which also means, the seat and the tank cover off, which is a pain in the ar$e ;)
    Also it would make it easier to secure the bike in the van....
    anyone has these available?? or know where I can purchase them? ( except ebay for 90£ )
  6. sps170373
  7. sps170373
    You could give iomtt a shout as he was making these for a lot cheaper
  8. megawatt
    megawatt Well-Known Member
    I can probably make whatever you want outta ally or stainless. Just need a good drawing and dimensions?
  9. IcarusGreen
    I'll most likely take you up on that offer Megawatt for my rr-4. I'll sketch a diagram at some point :D
  10. Skippy79
    I'll have a look to sketch something up over the x-mas period..
    @sps, don't you think it's a lot of money for what it is?
  11. Skippy79
    does anyone have a set they want to outline? ;-)
    or can someone measure the holes from their pegs that they don't have on anymore? need from center to center... thanks
  12. megawatt
    Here to help gents.
    Bit dear for my wallet, but they are sculpted and anodized. Mine would be polished ally or stainless, slightly chamferred.
    #12 megawatt, Dec 23, 2013
  13. sps170373
    I think so yes! But I guess if you look at design, development, testing, materials, coatings, holding stock that's where the costs go.
  14. sps170373
    These are the sato dims if you want to make some from scratch! One of the other members posted these up a while back
  15. Skippy79
    that's great sps... thanks... now lets see what megawatt comes back with..
    I dont really need the big hole at the bottom, as I wont be using it for transport ratchets. the arche at the bottom isn't needed either, just straight on straight.
    Have a look Megawatt and let us know...
    thanks
  16. sps170373
    Your welcome mate! Mine aren't sato I got mine from ebay but were made by speedox a member on here
  17. megawatt
    Was hoping you wanted something with minimal sculpting on it and the same thickness all over. I don't have a milling machine , but will have a go at reducing the thickness of a small area. I make alloy parts using my vertical bandsaw, a pillar drill , an angle grinder and various filing / polishing tools. The longer it takes me , the more it will cost. I would obviously round off corners and make sure other parts aren't fouled by the brackets. Could the part have a slight bend in it instead of being machined thinner? 10mm thickness is completely unnecessary, 6mm alloy or 3mm stainless would more than do the job. If someone could do a simplified , scale drawing, so that I can copy it onto graph paper, cut out and drill, I will have a go after New Year and you can see what you think. I suspect the holding bolts are M8 thread?
  18. sps170373
    M8 with clearance (8.5mm) for bolting to frame and M8 threaded for footpegs or exhaust hanger as skippy wants
    #18 sps170373, Dec 23, 2013
  19. megawatt
    Quick sketch of a possible bracket using the dimensions given;
    Does the hatched area at the top need removing?
    I see from the Sato picture that the front section does need relieving. The simplest,cheapest way to get around this is to place a spacer washer behind the top left bolthole to give clearance at the top right bolthole?
    The hatched area at the bottom could be removed, but no good reason for it, if the 25mm hole not required?
    Blank drawing of bracket with no relieved areas.
    Thoughts please chaps?
    #19 megawatt, Dec 24, 2013
  20. megawatt
    So, no interest in these brackets now? Or did I get something wrong?
