Rear shocker question
Discussion in 'Maintenance' started by G Y Bry, Sep 22, 2019.
  1. G Y Bry
    G Y Bry New Member
    Hi guys looking for a bit of help. The Blade was booked in to have the suspension set up but been let down. My question is it says the spring pre-load setting for standard is position 4.is this from the softest or hardest position.
    Forgive my ignorance and any help appreciated.
    Cheers
  2. Shutty
    Shutty Well-Known Member
    From softest.. im 13.5st and have it on 6 which is hard.. 5 would better depending in your weight and what it does to the sag
  3. G Y Bry
    G Y Bry New Member
    Thanks for that mate I've adjusted it to 4 but going to check sag etc. As soon as I adjusted pre-load it started chucking it down and hasn't stopped. I'll see if I can get someone to help next decent day we get to adjust as needed
