rear shocker
Discussion in 'Maintenance' started by racman, Jan 22, 2014.
  1. racman
    racman Active Member
    Hi guys, just put rear shocker back on rr6, took off for routine maintenance. Torqued everything up as the good book says to 44nm. There is a small ammount of play now if you get hold of it, ie from left to right. Didnt check if this was there or not before i took it off. Bike is on abbastand so no weight on shocker, so i think the free play should be ok. Does anyone know if this is correct
  2. Gilesy
    Gilesy Elite Member
    Isn't there a ball joint on the top of the shock? I think mine did that before changing it for the ohlin..
  3. racman
    I think you are correct. Anyone else know any different?
