refit servo cables 2018 SP - struggling
Discussion in 'Maintenance' started by Kevin1, Nov 26, 2020.
  1. Kevin1
    Kevin1 Elite Member
    I'm struggling here.
    Out of boredom I decided to put my standard exhaust back on my bike. Taking the Yoshi off is a doddle.
    But...I can't refit the servo cables to the servo motor. There just isn't enough slack to hook the cables on the motor.
    Suggestions? please.
    I can't even find anything on Youtube.
    DONE IT
    I took the plastic pulley off the servo. That pesky grub screw needs to come right out as it passes through the spindle. You still need to apply a bit of effort but it is possible to get the plastic pulley back on.
    DON'T FORGET TO LEAVE THE BLACK PLASTIC SHROUD ON THE CABLES. THE ADJUSTER CABLE MUST BE THREADED THROUGH THE SHROUD. Otherwise you have to take it all off again...don't you Kevin
    #1 Kevin1, Nov 26, 2020
  2. sandman3791
    sandman3791 Active Member
    When changing exhausts i just wind the round server part back so it is in the open setting so you can hook it in
    Mine is a 2013 model though
    When you start the bike it then resets
  3. PauloHRC
    PauloHRC God Like
    Hi Kevin, I've just put my standard can back on my 18 as well. I left the cables off though, decided it wasn't worth it as it ran well with the Arrow on so it can't be any worse. What I would say is.....have you tried fitting the cables to the servo first, then to the exhaust afterwards, obviously you'll need the exhsust off to attach the cables at that end to finish.
    Just a thought as its what I was going to try if I'd of put the cables back in place.
  4. stelwalker
    stelwalker Member
    Just slackened off the adjuster at the end of the cable on mine. Stuck my thumb there to guesstimate where it needed set back to if ever needed
  5. Kevin1
    Kevin1 Elite Member
    I managed in the end. See above
  6. Kevin1
    Kevin1 Elite Member
    Paul
    Have you had a Honda dealer lock out the servo. If not, it can damage the servo
