Hi Looking for a couple of regulator rectifiers for 2009 cbr1000rr. Thought I’d try here before buying from eBay Thanks
Something to keep in mind is that ABS and Non-ABS reg/recs are different so you don't accidently buy the wrong one. The non-abs has plugs directly onto the body, while the abs one has a ~15 cm wire coming out and the plugs are different also.
Thanks for the warning Mine has 2 plugs directly on top of the unit and no wiring so sounds like the non abs version. Thanks
