Removing the Front Sprocket on a ABS Blade
Discussion in 'Maintenance' started by Remal, Dec 11, 2014.
  1. Remal
    Ok I have the bike in a few bits. new Chain and Sprocket came today and all I have to do is find out how to use my old but never used chain tool :roll eyes: but also how to remove the plastic cover over the left of the blade. Which from my understanding covers ABS leads etc..
    Anyone removed the plastic cover on the Left engine side without removing/ loosening the fairing?
    Any tips?
    I've been looking on Ytube to see if there is any clips but found nothing yet
    cheers
  2. Slick
    Slick Elite Member
    You will need to remove 1 fairing bolt and the gear selector to remove the abs cover. Removing you just pull it off refitting takes a bit of a knack
    NB You should be able to loosen the sprocket nut using the rear brake alone
  3. Remal
    cheers bud. before I started this I wanted to know what I was doing and the downloaded Manual is now showing me much about the cover
    But I know a little more now
    cheers
  4. sinewave
    Yes you do need to remove loosen 1 fairing bolt but that's all.
    Comes off easy enough but refitting requires some gynaecology skills! :rolleyes:
    I hope you've dropped a tooth off the front for better acceleration? ;)
  5. Slick
    Slick Elite Member
    dunno if I mentioned it but GB racing covers fit under the ABS cover. essential mod for any bike IMO
  6. Remal
    Yup 1 up on the rear and 1 down on the front. And good heads up on the GB racing covers as I only have them on the right side at the moment as I was unaware they would fit under the plastic cover
  7. RRoss
    RRoss Active Member
    Just leave it off,I did. Got some stainless steel bolts from pro bolt to tidy it up and let's you keep bike cleaner as dirt gathers behind the plastic cover. Looks better too IMO.
  8. Remal
    And leave the sprocket cover off? is that a good idea?
  9. RRoss
    RRoss Active Member
    i kept the sprocket cover on after giving it all a good clean. Just didn't bother fitting the larger plastic cover back on so both sides of bike look the same i.e. You can see the engine casings.
  10. Remal
    might be easier and good idea on that. And I will probably do that myself
