Removing transponder chip from HISS Key
Discussion in 'General 1000RR Discussion' started by floppy26, Jan 20, 2019.
  1. floppy26
    floppy26 New Member
    Hi.
    Can anyone offer some insight into hoe to remove the transponder from the HISS key. I am replacing the Lock-Set due to some scrotum trying to steal my blade and obliterating the ignition lock (among other things). I was hoping to remove the transponders from the current key and putting them into the new keys for the new lock set. Are they located in inside the plastic under the Honda logo or elsewhere?
    Thanks
  2. gixxerjim
    gixxerjim Active Member
    My mate got a new key cut and just kept the original top part taped to the new key.
  3. sulaco
    sulaco Active Member
    I had a key cut and removed the transponder form my old key and put in in the new key, mine was like this :2005 blade
  4. floppy26
    floppy26 New Member
    Thanks for the replies guys. Should have mentioned the key is the new blade shaped key (for the 2013 - 2016 models).. i may end up just hacking the hell out of one of these keys to find where it is.
  5. floppy26
    floppy26 New Member
    Hi Guys... Finally got to the bottom of my own question by hacking the hell out of the key i have... I can now report the transponder chip is slap-bang in the middle of the black plastic - not easy to get to. Answered my own question but hopefully useful info to others too.
    • Useful Useful x 4
  6. Boothman
    Boothman Elite Member
    Nice bit of whittling to get to it itch out causing ny damage - well done
  7. Jez
    Jez Senior Member
    I bought a chip and key for my 2013 off ebay, I got local keycutter to do the key then programmed the chip as per youtube all went well
