Rivet peen
Discussion in 'Maintenance' started by BoroRich, Feb 15, 2015.
  1. BoroRich
    BoroRich Elite Member
    Afternoon all.
    Been having a bit of a wrestling match with my RR4 whilst changing the chain and sprockets (didn't know that the clutch release mechanism was attached to the front sprocket and needed to be removed :rolleyes:).
    Anyway it's all back together but I've a question. How much rivet peen do people generally do.
    I'm using an AFAM chain and after the bit of peening I've done the rivet heads are around 5.25 mm. Does anyone have any advice on how far you're supposed to flare them?
  2. Muffking
    This is one of those jobs that you can easily spend more time thinking about than is necessary.
    I had mine opened up by my local bike garage as I didn't have the right tool, but most importantly I measured the width of the link with a calliper gauge to make sure it was the same as the others so it's not too loose & not too tight.
  3. BoroRich
    Perhaps a pic might help. Does this look ok???
  4. Muffking
    looks good, but to be sure if you take a pic from an angle then it might be easy to check that the rivets fan out ok.
  5. racman
    racman Active Member
    looks perfect
  6. megawatt
    megawatt Well-Known Member
    Looks great. You don't need hardly any peening. Look how difficult it is to get the sideplate onto the pin? I usually finish off with a ballpein hammer anyway.
  7. Sam
    Sam New Member
    Looks fine, confidence is the key
  8. Kentblade
    Kentblade God Like
    Rich
    No issues with that mate.
    The most important thing is to get the setting tool square and make sure there are no cracks in the rivet head when flared.
    The stress on the joint is in line with the chain travel, not side to side, so all you are doing by flaring is stopping the rivet coming loose.
  9. arthurbikemad
    Looks perfect!, other than the renthal sticker needs to be moved down a bit :D
  10. BoroRich
    I noticed that when I put the picture up :D
    It was already on there. Someone at the factory didn't do a very good job.
  11. t0m541
    t0m541 Senior Member
    Spot on that Rich... :D
  12. BoroRich
    Cheers, Tom :)
