RR 9 clutch banging into 1st
Discussion in 'Maintenance' started by Broadie, Aug 25, 2020.
  1. Broadie
    Broadie Active Member
    Hi guys. Got an issue with the clutch going into first form neutral. It's making a big old bang been getting worse lately.
    Bikes close to 50k think it was a commuter bike before. I removed the clutch basket expecting the basket to be notched up, but it absolutely fine.
    So im a little stumped, could it be stack height or plates just gone off they look okay.
    Any help or suggestions would be a great help?
    Thanks broadie
  2. Muffking
    Adjustment of the clutch cable/lever?
    Are you able to rotate the rear wheel by hand with the clutch lever pulled in when the bike is in gear?
  3. Broadie
    Yes cable is adjusted still happening even if I overtighten the cable. Once the gear is selected there's no drag I can keep the clutch in and shift up and down all the gears.
    Cheers
  4. Muffking
    Could be a gearbox issue with 1st then. I'm not sure if these are a cassette type gearbox like the earlier ones, but if they are then it would be easier to have removed and looked at.
