RR4/5 caliper mounting
Discussion in 'Maintenance' started by mk3golfcab, Apr 24, 2020.
  1. mk3golfcab
    mk3golfcab Elite Member
    Hi all, after sizes to make @Gravel trap some washers to fit RR6/7 discs.
    Struggling to find out the diameter of the fork leg where it meets the caliper if anyone can measure for me? Also after the bolt size, am I right in thinking it is an M8 bolt that holds the callipers on? Or is it M10? Cheers
  2. Iain
    Iain Active Member
  3. mk3golfcab
    Thanks Iain that’s a great help, do they have a lip on to keep square to the fork legs? If that makes sense?!
  4. Iain
    Iain Active Member
  5. mk3golfcab
  6. Muffking
    Did you get it sorted as I'm just popping back to the garage to carry on fettling.
  7. Muffking
    5mm spacer, 24mm od M10.
    I've not removed it to check the internal dimensions.
  8. mk3golfcab
    Thanks Gary, Gravel trap has ordered one so will copy straight off that :)
    • Friendly Friendly x 1
