if anyone has a pc and qs id like to buy it plus if anyone knows do i need a ignition module as well. id also like a shock if anyone knows of anything thanks for looking cheers
i want to be able to fuel the bike as well, the HM will only allow qs to be installed ive had stand alone qs that only cut spark before and they can be tempremental at best, also quite had on the gear box. the cut of is usually set at 50 mS.
Go for the HM GP model if you want real flexibility with setup! Can vary cut time on a per gear basis if you want too. Everything pretty much comes down to budget no matter the product, shock/forks, fuel module, q shifter, to buy new or buy second hand it's all pretty much dependant on budget and availability of wanted products!
