RR5 bits
Discussion in 'Parts, Accessories & Clothing' started by bluekontakt2004, Jun 8, 2012.
  1. bluekontakt2004
    bluekontakt2004 Active Member
    Power comander 5, complete with the box, software and all the fitting instructions that it came with. Will fit RR4 to RR7 but RR6 and RR7 require an oxygen sensor thingy. SOLD
    Yoshimura GP Force end can with all clamps, bolts and springs for fitting. sadly the baffle is awol. £180 ovno
    PPtuning shorty adjustable leavers in black. clutch and brake. SOLD
    Colour coded (blue) rear hugger (some stone chipping) £40 ovno
    Open to sensible offers.
    #1 bluekontakt2004, Jun 8, 2012
  2. BoroRich
    BoroRich Elite Member
    I might be interested in the Power Commander, mate. I've never had any experience with them though. Are they easy to fit and what benefits do they give??
  3. bluekontakt2004
    With a custom map done on a dyno you can get more power, smoother acceleration and better mpg.
  4. BoroRich
    Ahhh cool. What about fitting? Much of a ballache?
  5. bluekontakt2004
    Fitting is a piece of piss mate, remove tank cover, seat, left hand mid panel and I found it easier to remove the tail and lift the tank.
    Then just simply connect the 5 connectors, 1 each to the lower injectors and 1 to the throttle position sensor, then 1 wire to the earth on the battery. Then your done.
  6. BoroRich
    You have PM :D
  7. bluekontakt2004
    Pm received and replied to.
  8. bluekontakt2004
    Also have a colour coded rear hugger in blue, Has a bit of stonechiping on the edge.
    Will get some pics up soon.
  9. bluekontakt2004
  10. bluekontakt2004
  11. bluekontakt2004
  12. bluekontakt2004
    levers and power commander now sold
  13. Toy40
    Toy40 Active Member
    what map were you running with the GP Force,I cant get mine running right at all!
  14. bluekontakt2004
    I put the gp force map on and got 80 miles to a full tank of fule!
    Then put the generic map on for no mods and that seemed to work.
    I then got a custom map done. You can run the power commander in 0 correction mode to check its fitted properly.
    Have you connected the injectors properly?
    You use the lower bank of injectors, the upper bank are for low revs.
  15. Toy40
    Toy40 Active Member
    There is only a Yoshi RSS map I could find. Yea all connected ok. It was a bit rough down low when I fitted exhaust and filter so setting to zero wouldn't help I don't think. Think Dyno the only way.
  16. bluekontakt2004
    There is a go force map, but it's for 06/07 bikes.
    The generic no mods map worked fine for me for a little bit untill I got a full map done.
    It seemed to get rid of the flat spot in first as you pull away which is where it was most noticeable.
