RR7 O2 sensor removal - blanking plug?
Discussion in 'Mods, Upgrades, Accessories and Products' started by GappySmeg, Aug 22, 2014.
  1. GappySmeg
    GappySmeg Well-Known Member
    Having fitted an O2 eliminator, my O2 sensor is redundant.
    Being anal about such things, I don't like the idea of having the sensor/wire attached to my bike doing nothing. I've googled around and cannot see a "blanking plug" or similar to allow the O2 sensor to be removed from the exhaust.
    Does such a thing exist? Is there a DIY solution? Anyone done this?
  2. Barstewardsquad
    Stick a cut down bolt in it.
  3. kev.b
    kev.b Well-Known Member
    PDQ sell them. brought one when I had my standard system fitted to my 06 Blade .
  4. sps170373
    Pdq in Slough sell them they are about £10
  5. GappySmeg
    Cheers gents, I will take a look at PDQ.
    On a related note I've finished fitting the PCV and the bike still works... miracle! Can't wait to test ride it tomorrow.
  6. Frost1
    Frost1 Active Member
    Most car spare shops sell'em, just ask for Lambda blanking plug, pretty sure they are 18mm thread.
  7. GappySmeg
    Hah... had been searching for "o2 sensor plug" and found naff all... but now searched for "lambda sensor plug" and unearthed a veritable cornucopia of options...cheers fella.
  8. Frost1
    Your very welcome pal, having a Subaru helps me with this stuff as it has 2 of them LOL.
  9. allbutt55
    allbutt55 Member
    You can order a N0160255 sealing plug from any vw dealer or tps site for about £2.50 this is a M12 x 1.50 pitch plug it will go in fine that's what I have put in mine the 02 sensor pitch is 1.25 but it will work!!
  10. GappySmeg
  11. wedgiewolves#223
    wedgiewolves#223 God Like
    Hi there use some permanent lock or a tab of weld when it gets warm mine kept coming loose and popping out in the end I brought some US headers no cat or bung hole around £50 delivered
  12. GappySmeg
    That's good info, cheers.
    I've spotted a lot of RR6/7 headers on EBay, thought they looked different... thats why then! Surprised US models don't have o2/CAT considering how serious they are about emissions!?!?
  13. wedgiewolves#223
    Yeah you would think I think the newer models do now
  14. Frost1
    As wedgie mine loosened and popped out. I took mine off to do it right, welded and removed cat at same time. :)
