RR7 Switched Live
Discussion in 'Mods, Upgrades, Accessories and Products' started by ledwardio, Feb 22, 2018.
  1. ledwardio
    ledwardio Active Member
    Does anyone know if there is a switched 12V feed easily accessible on the RR7 Blade?
    The bike came with heated grips but they are wired straight to the battery so its vulnerable to someone turning them on when its parked and flattening the battery.
    Cheers
  2. sulaco
    sulaco Active Member
  3. ledwardio
    That looks like an option, thanks.
  4. Muffking
    They're pretty good if you can get the cover back on, but make sure it's in the right way around as you want the supply to go through the fuse first.
    I usually just tap in to the headlight or side light as they're always on with the ignition.
  5. nigelrb
    A very similar thread to this on the MV Forum, where a guy wants to independently switch on his fans. Without hijacking ledwardio's thread, has anyone done that with the Blade? (Might be more of an advantage in warmer climate)
  6. ledwardio
    No need for that in Yorkshire me thinks :D
