S1000RR Sport
Discussion in 'Other Bikes' started by Blix, Jul 16, 2017.
  1. Blix
    Blix Active Member
    My mate has bought this and I got a chance to have a decent run out on it today......
    Hmmmmm.....
    Good points,
    masses of low down power, pulls like a train much further down than my Blade (14).
    Brakes are outstanding, never touched the back as I never needed to.
    Quickshifter seemed to work well up and down but it kept using the clutch out of habit.
    Turns, goes and stops very well.
    Bad points
    Throttle seems to do what it wants with no predictability, 1/4 throttle seems to give power sometimes and then not, it's a new bike so this may improve.
    Switchgear is terrible, looks cheap and the indicator is basically a guess as to whether you've activated it or not.
    Bars were quite vibey at lower speeds, seemed to improve as you went quicker but I could definitely notice it through the villages.
    This might not be a negative to everyone but it's stupidly fast without any sense of speed, 100mph skips past feeling like about 60 or 70.
    Finally although it's a great piece of kit I found it a bit lacking in something I just can't put my finger on, not memorable at all.
    I jumped back on the Blade and it felt like home
    So all I all a great bike but just didn't float my boat.
    I do feel my brakes need sorting though ;)
  2. Gaffa22
    Gaffa22 Well-Known Member
    I agree with your findings Blix, i've ridden two demonstrators.
    I didn't like the QS it felt very wooden on down shifts and sometimes it didn't shift.
    Interesting you say the switch gear looks cheap, they have had lots of failures, BMW were even replacing the out of warranty failures but have stopped that now, and at £200 a time some peebs are going to be pissed of when warranty expires and they fail.
    The vibes through the bars is very common, there's guy on the S1K forum who makes extra heavy bar ends which is supposed to help so its obviously a very common problem.
    Performance wise the power delivery is a little more brutal than the new blade but there's not much in it, much more noticeable compared to my 2009 blade as you'd expect.
    I very nearly bought a 16 plate S1000RR a the end of last year, but like you I felt there was something missing or not quite right,
    I am so glad I waited for the 2017 Blade, I think it will turn out to be more reliable and less costly if kept after warranty has expired.
  3. Blix
    Blix Active Member
    Yes the quickshifter was a bit odd, seemed to work fine sometimes and then just didn't even though I was booting it up harder than my old Kat, I ended up just using the clutch.
    I can't really say it's a bad bike but just characterless. He's getting a little exhaust to try and make it a bit louder but as it's got a Euro 4 cat I doubt it will change it that much.
  4. Cbrjay
    Cbrjay Well-Known Member
    What mode did you have it in?
  5. Blix
    Blix Active Member
    Race apparently, I didn't set it to that, it's my mates bike and that's what he said it was on.
  6. Cbrjay
    I've only ever had mine in slick mode
  7. Blix
    Blix Active Member
    I'll let him know, I guess it's a bit more ferocious in that mode on road tyres.
    One time coming out of a corner it felt like the back wheel was sliding but didn't feel like a slide, just felt I was moving sideways in a controlled manner, I know that sounds odd and it's probably how you would want a bike to behave but again sort of disappointed.
    I'll wait til he's had it a few months and then see if I can blag a go in slick mode.
    Also turns out he'd fitted after market levers which were playing up with the QS.
  8. Cbrjay
    They have a bracket or some thing on levers, think race you still get full power but more abs etc
  9. Jimbo Vills
    The exhaust will make a huge difference too.... take the cat off a 16 zx10 and it's like a different bike.
    They are standard rearsets, how do levers affect a quick shifter?? Never heard that before....
  10. Blix
    Blix Active Member
    Clutch lever has a switch which does something to the QS in launch control mode apparently, you pull the clutch lever in slightly and it deactivates the QS, so I'm told.
  11. Cbrjay
  12. Lozzy
    He probably pressed the disagree button by accident I'm always catching the sodding things as I'm scrolling :rolleyes:
  13. We'reallfireBladesarntwe?
    Sorry didn't no I had.must have just pressed it by mistake.
    • Disagree Disagree x 1
  14. Cbrjay
    ok mate no worries
  15. gary1966
    gary1966 Active Member
    Same as above nice bike but nothing special and it's a fair step up from the 2012-2014 model that is total dog shit imo
    I would have my 14 sp over the current bmw and the new standard blade
  16. Blix
    Blix Active Member
    Just as an update he tried to put his bike in slick mode by sticking the dongle in (ooh-err) and it wouldn't activate saying he didn't have the correct options, even though he has every option other than mag wheels.
    Got to go back to dealer to check the software.
    Bloody electronics, I'm happy to sacrifice a few ponies for a cable throttle ;)
  17. Cbrjay
    has he had 1st service done? Dealer take limiter off then
  18. Blix
    Blix Active Member
    Yeah that's why I waited to have a go on it after the first service.
  19. Cbrjay
    im sure I red a few times dealer not taking limiter off properly, so may be done to that
  20. Cbrjay
    i much prefer the bmw to my old 14 plate blade
