SCORPION EXO 1000 size L
Discussion in 'Parts, Accessories & Clothing' started by Waynenorris, Apr 18, 2016.
  1. Waynenorris
    Waynenorris New Member
    IMG_20160418_174718.jpg IMG_20160418_174603.jpg A+ condition only worn 3 times £150 ono + postage thanks guys please see spec below :
    • TCT® (Thermodynamical Composite Technology) tri-composite fibre outer shell for high energy absorption and progressive deformation in the event of impact
    • Triple-density EPS (expanded polystyrene) shell for improved comfort and safety
    • Removable washable Kwikwick2® fabric interior, known for its improved skin breathability and enhanced moisture absorption properties
    • Airfit® system using adjustable air cushions for improved fit and optimum comfort
    • Visor fitted with a MaxVision® Pinlock system to prevent condensation and provide high-performance anti-fog protection
    • Speedshift® system means you can replace the visor in 10 seconds
    • SAS® innovation which automatically presses the visor against the helmet when open or closed ensuring a perfect seal and optimising helmet aerodynamics
    • Three-position visor catch gives you visual and sound comfort in all conditions
    • Internal Speedview® anti-fog sun visor - two independent visors makes it easier and quicker to use than a pair of sunglasses
    • Various air channels with adjustable front air intakes and two rear extractors for improved helmet ventilation
    • Three-position chin guard for adjusting airflow
    • Removable chin cover and breath guard
    • Quick-release double D-ring (removable washable protectors) for a perfect strap fit and stronger hold every time the helmet is worn
    • Weight: 1500 g (+/- 50 g
