Sidestand switch removal 12 cbr1000rr
Discussion in 'Mods, Upgrades, Accessories and Products' started by wedgiewolves#223, Oct 10, 2014.
  1. wedgiewolves#223
    wedgiewolves#223 God Like
    Is it a case of the good old way of just joining the 2 wires together when side stand removed from the blade cheers everyone
  2. Garyb
    Garyb Moderator.
    I'd say the good old way 'joining the two wires to close the circuit' should be fine.
    But, never been a fan of this method If another switch, in this instance the clutch lever is sharing the same circuit.
    Peace of mind put a small resistor in line.
    Or remove the switch from the clutch lever at the same time?
    I think that's right?
  3. wedgiewolves#223
    Hmmmm never thought of that and I'm a wiring nightmare ha ha cheers buddy
  4. sinewave
    I'm a big Fan of keeping a side-stand in the absence of one's own Pitcrewe, makes things far easier in the Garage and if it doesn't touch down (which most don't) then keep it.
    It's not like any of you are that good that saving 500g is guna make U any quicker is it? ;)
  5. Garyb
    Garyb Moderator.
    Ha, I was just going to shout you then J.
    Think we had this discussion with Jase while we was away 'and bolting his side stand back on'
    Sure i heard correctly the racing lads have to remove them?
    You know, one less missile through the air and all that ?
    Of course could be total bollox, it's been a long week ;)
  6. Mad Matt
    Trouble is he will be racing the Blade and the side stand needs to go i presume??
  7. sinewave
    Don't think so, there is no requirement for removal as far as I know, tiz just doing what the BSB Lads do that's all.
    They however have the luxury of a Full Pit-Crew to hand over and take back the Bike on to paddock Stands after a stint, where as Joe Bloggs has to do all this him self.
  8. Mad Matt
    I was informed on TDR that it had to go in accordance with ACU regs, maybe one of the lads that are racing could enlighten us...
  9. Garyb
    Garyb Moderator.
  10. wedgiewolves#223
    Yeah side stands need to be removed as in all ACU regs as far as I know so any club abiding by ACU regs has to have centre and side stand removed
    #10 wedgiewolves#223, Oct 10, 2014
  11. wedgiewolves#223
  12. Mad Matt
    Horns must be working?? Thought they had to go??
  13. wedgiewolves#223
    Defo gotta be removed as well horns well for no limits and Hottrax anyway this was just a piece I picked up ng street stock regulations . Must be different buddy
  14. sinewave
    Fair enough, I stand corrected if Racing then.
    Makes sense to keep one for just Track Day use though.
  15. wedgiewolves#223
    Yeah defo Jay it is a pain the arse even loading up on your own and that
  16. Jimbo Vills
    It's to do with the belly pan having to catch oil, side stand leaves a hole and therefore doesn't catch oil...
    Tbh I don't miss the side stand, easy enough to do on paddock stands. Then, I do have a pit crew ;)
    Seen some lads with a little tripod that goes in rear spindle, that's a great idea and easy to use single handed
  17. wedgiewolves#223
    Yeah saw them also to slot onto foot peg
  18. sinewave
    Paddock stands only work if you have bobbins matey!
    Unfortunately yours snapped off at Donny! ;)
    Your Bikes safely in the back of Barney's Van now and should be with you early this evenin'! :)
  19. Jimbo Vills
    Ha ha, I know, will have to lash that or a new polished swing arm might be going on ;)
    Thanks mate, appreciate that mate! Owe ya a pint at nec. :)
