solar power for lighting in a powerless garage.
Discussion in 'Mods, Upgrades, Accessories and Products' started by Kevin1, Jan 25, 2014.
  1. Kevin1
    Kevin1 Elite Member
    I went with this supplier in the end
    Solar panel kits; 12v Solar battery chargers; off grid solar power
    The guy Curtis, seemed to know his onions. I'll let you know how I get on. I have gone for an 80Watt panel because I want to have the option of installing a burglar alarm and an outdoor LED PIR light. It will be this weekends project.
  2. Kevin1
    Kevin1 Elite Member
    What size battery are you running Sine?
  3. Ritchierich
    Ritchierich Elite Member
    I've got a couple of 95 amp battery which we replace on a couple of BMW's at work, joined together in parallel.
  4. Yorkshire Tyke
    Yorkshire Tyke Elite Member
    I would guess 16mm^2 and because you can potentially draw upto 167A with that!! how much was the setup sine?
  5. sinewave
    Standard Vivaro Battery Kev, only used TBH whilst engine is running!
    50mm2 YT ;)
  6. Kevin1
    Kevin1 Elite Member
    Rich
    For a better quality light maybe you could try these.
    I think they are very good compared the fluorescent light.
    Sunstore - 12v 7w LED bulb for solar application
    I also notice from your pic you aren't using the lighting terminals on the controller unit. Is there a reason for this?
    I have also used one of these, 10W flood lights for outside the garage door. The light output is surprisingly very good, but the amount the light head unit can point down is restricted due to the PIR sensor at the bottom. I may try mounting it "upside down", but I can only do this if the PIR head will swivel 180 degrees.
    http://www.sunstore.co.uk/10w-12v-LED-Flood-Light-B-LED10WPIR.html
    #26 Kevin1, Feb 17, 2014
  7. Ritchierich
    Didn't use output terminals on control as when the battery voltage drops below a certain voltage the control unit switches feed to those terminals off.
    Thanks for the heads up on the bulbs Kev.
  8. Kevin1
    Kevin1 Elite Member
    Does the voltage dropping too low happen often
  9. Ritchierich
    Does if I use the inverter a lot but then again my panel isn't as big as yours wattage wise and we have had a lot of bad no sunshine weather too :-(
  10. Ritchierich
    Took your advise Kevin and brought the LED screw in 12v bulbs, brilliant :)
    New bulb on right to compare.
