sp chain and sprocket
Discussion in 'General 1000RR Discussion' started by keithg1748, Jul 7, 2019.
  1. keithg1748
    keithg1748 Active Member
    hi all i was just wondering if anyone has changed the standard chain and sprockets yet ?
  2. Shutty
    Shutty Active Member
    Yep
    Renthal 44 teeth (+1) and gold did chain 116 link.. just remember on new SP its a 525 width not the 530. Still need to get round to fitting the chain
  3. keithg1748
    cheers.
  4. keithg1748
    where did you buy these from ?
  5. Shutty
  6. keithg1748
  7. nevsrevs
    nevsrevs New Member
    What year have you got as if you have a 17/18 changing sprockets sizes will have a negative affect on certain electronics on your bike
  8. Shutty
    116 links and stated to fit, tbh i haven’t fitted yet, going for tyres next mth so will fit then. The sprockets on and even at +1 its fine with the electrics and made a slight diff but not a lot to performance
    #8 Shutty, Jul 7, 2019
    • Useful Useful x 2
  9. nigelrb
    That's very interesting given the lengthy discussions about error codes etc. I wonder if the effects on, say, traction control and ABS might not be noticed unless the bike was really put under severe stresses? Any observation of negative effects?
  10. nevsrevs
    nevsrevs New Member
    Be very careful with your down blipper, it seems fine for ex amount of miles and then it will decide to stop working all together, you will get just a line come up on gear selection screen. Traction control is a lot harder to feel unless your at a certain limit on corner exit loading up,
  11. Shutty
    Had as hard a ride as i will prob give it on Friday on 170 miles without fault so will see how it goes. Couldn't really say that noticeable difference, traction on 3 was noticeable on acceleration, (lots of winding Yorkshire B roads with the odd bit of gravel to surprise you) maybe my head but poss more than normal but back tyre is prob 2/3 worn, hard to say but on 2 i couldnt feel it kicking in. Down blipper was fine and it got a bit of use, no dash issue etc
    Now you have me paranoid but couldnt find a Renthal 525 43T to fit.
  12. nevsrevs
    nevsrevs New Member
    The way I can explain it is like someone putting the back brake on coming out of the corner, feels like the bike has a massive flat spot on the throttle, this is on track mind so not sure wether I could get it to do it on road conditions myself. Blipper wise almost put money on having no gears every session, this is with 3 2018 bikes all riding together
  13. keithg1748
    yes im the same couldn't find a renthal 43t 525 to fit. theres a 411-525-43t ha but that fits a 600rr ,
  14. keithg1748
    chain and sprocket fitted today , but im a bit paranoid on the flaring of the link , ive done it but when I checked they where faired to 5.5mm but according to the did chain site for my chain it should be 5.7mm - 6.0mm , and ive done it as tight as I can and my chain tool just slackened off , it doesn't look like ive trashed them but any help would be great , thanks.
