Spark plugs when?
Discussion in 'Maintenance' started by LowSide76, Jan 2, 2021.
  1. LowSide76
    LowSide76 Active Member
    I have 2015 cbr1000rr thats on 8400 miles, I've done about 3k since buying it in May.
    Would you guys change spark plugs over winter or leave them as mileage doesn't warrant a change I dont think according to manual.
  2. Selmer50mark
    Selmer50mark God Like
    Have a look at 16000 when the shim check is, because your in there anyway
    • Agree Agree x 2
  3. Trackit
    Trackit Active Member
    The spark plugs are rather expensive and are relatively big job to replace, I done mine at 14 000 miles purely as I was fitting a quickshifter at the time, I wouldn't replace them at 8400 miles.
  4. LowSide76
    I will give them a miss for a bit then. I'm just funny with doing things. Was just thinking theyve been in for 5 years
  5. bradt
    bradt Elite Member
    Had mine replaced at 16k
  6. Slick
    Slick Elite Member
    did over 70K with last RR, didn't shim or change plug in all that time:eek:
  7. LowSide76
  8. Kentblade
    Kentblade God Like
    Jeez I thought I was tight going 95K without checking the shims, but 70K on plugs, have a gold star brother, you must have a lot of Yorkshireman in you :D
    • Funny Funny x 3
    • Agree Agree x 2
  9. Slick
    Slick Elite Member
    I'm a Filipino, perhaps similar to a yorkshireman it only needs fixing if its broken! Our Jeepney is a testament to that, most are based on WW2 jeeps, TBH most are hanging but still going!
    I got the shims checked at 16 and 32k and they didn't need doing, got bored after that. I had a PCV and autotune so the afrs were spot on forever!, engine and throttle response was silky so didn't even both with plug either!
  10. dern
    dern Well-Known Member
    I follow the service guide as per the miles except for oil and brake fluid and then do that by miles or time, which ever is less.
    You'll get people telling you not to bother with some aspects such as shims and some, like me, who did them and it did need adjustment but this will have no bearing on what your bike needs. Your choice is to follow the service schedule or cross your fingers basically.
  11. bonjo
    bonjo Active Member
    changed mine @ 1k service purely because of the valve clearance adjustments.
    TBH I didn't notice any difference in performance nor MPG with the new plugs so 32k honda interval is realistic
  12. Kevin1
    Kevin1 Elite Member
    Spark plugs - It's a product we don't really think about anymore. In the 80s I'm sure we had a replace the plugs at around 2500 miles but nowadays they are just fit and forget. That's probably why they are sooooo expensive these days.
  13. CharlieR85
    CharlieR85 Elite Member
    Probably a combination of iridium plugs being commonplace and more efficient engines with tighter tolerances etc.
    I'll be changing mine when I do valve clearances at 16k.
