Splitting chain from 120 to 116 links ?
Discussion in 'General 1000RR Discussion' started by Lucky13, Jun 10, 2018.
  1. Lucky13
    Lucky13 Active Member
    Hi guys
    I’ve got to shorten a 530 chain down from 120 links down to 116, is it as simple and obvious as just counting 8 pin holes back and removing the pin at the 8th hole or is it the 7th hole ?
    Sorry if it seems obvious I just want to be 100 sure :)
  2. Slick
    Slick Elite Member
    You adding a extra joining link
  3. Lucky13
    Yes there is an extra rivet link included in another bag with the new chain.
  4. Slick
    Slick Elite Member
    If you have a 120 link kit the chain will have 119 + the extra rivet, so you should only need to remove 4 side plates.
    The sure fire way is to count 115 side plates and break at the end of the 115 side plate
  5. Lucky13
    Thanks all done and riveted back up :D
