Spot The Difference
Discussion in 'Mods, Upgrades, Accessories and Products' started by garyauk, Mar 14, 2012.
  1. garyauk
    garyauk Active Member
    I finally gat around to fitting these to my bike!
    I had these made to that they match the frame as best as we could get them, and I must admit I'm chuffed with the outcome
  2. Si.
    Nice!
  3. dave d
    dave d Elite Member
    neatens it up gary....:)
  4. KRL
    KRL Active Member
    Ooh helloooo, likey
  5. Andrew
    Andrew Active Member
    They look nice, expensive, where from?
  6. garyauk
    These were made by a friend of mine, 2 brackets, 4 spacers and the bolts I sourced myself..........oh, and he owed me a favour so they were free!
  7. Andrew
    What is it you've capped the bolt holes with?
  8. Remal
    Nice I want to get them Sato hooks before I take mine off so I can put them on if I need
  9. stevebetts
    stevebetts Well-Known Member
    just put mine on tonight as well!
    Great minds and all that!
  10. dan.1moore1
    loads better
  11. garyauk
    I've capped the bolt holes with black trim clips that hold the panels on a rear door of a Ford Transit
  12. Swiss T
    Swiss T Active Member
    Excellent idea!
    The are probably better for the pillon too as they will be a bit lower. :)
  13. garyauk
    They do sit about 30mm lower, but they are also about 10mm wider out each side. I even got my pal to sit on the bike with my miss's on the back to check for clearance.......if only I had a video clip of when I askek them to both bounce up and down :)
  14. stevebetts
    sounds like a scene from a bad porn film! :)
