Sticking ignition barrel
Discussion in 'Non Bike Related' started by Givover, Jan 17, 2014.
  1. Givover
    Hi dudes I have just bought a van which is mint but the ignition barrel is tight and its hard to turn the key .I have just googled this issue but some say use WD and others say don't is there something else I can spray down there?
  2. Tom68
    Tom68 Active Member
    Mate of mine couldn't turn his ignition on his Corsa at work yesterday, got a good squirt of wd, right as rain. I cant see a problem with it as the garage said thats all it wanted when he had it in for a service.
  3. wedgiewolves#223
    wedgiewolves#223 God Like
    Brake cleaner first then use some silicone spray . Also check key hasn't wore and the tumblers are finding it hard to recognise key . If you have a spare key try that first
  4. Givover
    Cheers gents I have all these products so a sesh in the morning will be undertaken and I will let you know the outcome .What a great forum when help is always freely given.
  5. cbr1
    cbr1 Active Member
    giv tuff shit:D buy crap accept shit sorry come on wd all the way just like Scotland were did u put that can lets go and find it :confused:
  6. Si.
    Did you get a Transit or Mercedes Vito dude??? If you didn't, what did you get in the end? :D
  7. Givover
    Have you had a stroke or something ?
  8. ShinySideUp
    ShinySideUp Elite Member
    Giv, Just so it's clear it is your van your trying to turn the key in the barrel right?
    You haven't just jumped inside a van and trying random keys in the ignition are you? :D
    Don't want the forum to be helpin you in an attempt to steal somebody else's van! :D
    Anyway on a more serious note the use of WD on the barrel will be fine as your problem most likely will be dried up and dirty old grease on the tumblers inside, WD will help to clean this and free all the internals off.
    but I would follow up the WD with another lubricant spray such as white grease (this is whats used during manufacture) as the WD will dry out causing the metal tumblers to grind together n become stiff again.
  9. Givover
    Ha ! Cheers Craig and although I am 45 mins from Liverpool I have not quite got the hang of the hot wiring routine. I took the advice off wedgie using brake cleaner ( A good blast) and I have a tin of lube spray called SP 50 I think and I followed up with this a perfect result !!!!!
  10. Givover
    Hi Si . I couldn't run to the expense of a new type Vito ect but dropped on an 05 mint both inside and outside Berlingo with a genuine 28 thousand miles full service history and Mot to back it up it seems to run sweet but later I need 4 tyres as the original tyres are on it and although they are only 25 % worn the outer skins are looking old and a guy said it would be due to the sun ?I was going to get a KANGOO just like yours ,but I didn't want everyone around here thinking a Rapist had moved in. ;)
  11. Si.
    hahahaha...lmfao.
