Hi you all, I'm new on here. Just fitted a HM superlite quick shifter. I have it on the most sensitive setting but still have to push the gear lever really hard. Anyone else had this issue? Thanks.
Does the shifter move enough on the rose joints? Can you push the lever to make the light come on as per the testing section of the manual? Most sensitive is 3 flashes from memory on start up. If you are still struggling, give HM a call. They are really friendly and helpful and should point you in the right direction.
Something wrong there as I had to set mine to least sensitive ... Else triggered too easily ... I'd be checking the linkage ..,
