Suspension settings for 12/13 Big Piston Fork models
Discussion in 'Mods, Upgrades, Accessories and Products' started by sinewave, Jun 11, 2013.
  1. sinewave
    After my recent trip to Kais Suspension I thought I'd post up their settings for anyone that wants to tinker.
    Front
    Preload is set at 5.5 turns from fully soft or full Anti clock (Don't know why, but Honda use base settings from a start off point of Full Soft/Anti Clock on this setting only, everything else is based from Full hard/Clock) :confused:
    Compression is 7.5 turns out from fully stiff or full Clock (I've now altered mine to 5.5 turns now as it dived too much IMHO when hard braking)
    Rebound is 3 turns out from fully stiff or full Clock
    Rear
    Preload is set at 5 out of 10 (Mines now on 8/10 to compensate for my Honda Hugger which keeps getting Twatted by the ABS housing! :rolleyes: )
    Compression is set at 3 turns out from full stiff or full Clock
    Rebound is set at 2 turns out from full stiff or full Clock
    I'm between 15.5 & 16 St depending on what the Mrs has spent in Sainsbury's that week.
    Hope that's useful to someone anyways! :)
    #1 sinewave, Jun 11, 2013
  2. vvtr
    vvtr New Member
    nice one cheers :)
    tbh im more than happy with the std setings so far, cant fault it :)
  3. sinewave
    Seems a few peeps asking about suspension setups today although none have stated what year their bikes are?
    Anyway here's a bump of this info for anyone that's interested. :)
  4. Kevin1
    Kevin1 Elite Member
    I just CBA. Too many variables for my liking. And I don't want the screws to have screwdriver marks in them.
  5. RedMacGregor
    RedMacGregor Active Member
    The screwdriver that comes in the Honda tool kit should fit by rights - just make sure you use the correct size screwdriver if not - the screws are not tight. I just carry the bit from a multibit screwdriver kit you can turn the screws easily (2012 suspension). If you don't fiddle you'll never know if you could have improved the ride and suspension from stock that's why the screws are there.
  6. Only1Matrixxx
    Only1Matrixxx Active Member
    Really?? Knowledge is power, mate...
    Might as well buy some shite tyres for your bike cuz there are too many to choose from...
  7. PeterT
    PeterT Active Member
    I shall give these settings a try later, standard settings do seem a little safe to me.
  8. PeterT
    Not bad but still not perfect, I have some other settings to try from another source, these being FRONT--- Prelaod 5 out from fully soft. rebound 2.5 out from fully HARD. Compression 3.6 from fully Hard. REAR- Rebound 2.25 out from Fully HARD. Compression 2.5 from fully HARD. I shall give these a try and report back.:)
  9. stuart_g
    stuart_g Active Member
    These settings are the same as on this website. Bottom of the page.
    Honda Sport Bike Motorcycle Suspension Settings - Honda Sport Bike Review - Sport Rider Magazine
    The Kais settings are interesting though. I had FTR suspension look at mine and they reckoned that with the standard front preload it gave too much static sag so incrased the preload to 10 turns in, they didn't quote what it was before and after though. Do you know what static sag you have with 5.5 turns? The rear was left at position 4 and 12mm static sag. I am approx 13 stone with riding gear. Compression and rebound front and rear are almost the same as yours.
  10. PeterT
    With 5.5 turns I am only getting around 18-20mm of sag which really is not enough for road use, obviously the front springs may also be to heavy which is what I had to change on my 2009 model, I used 9.5nm springs which were ideal for my weight which is also 13 stone with gear on.
  11. sinewave
    So are the standard Road springs better for Heavier Riders which I spose makes sense as Honda have to allow for Pillions as well in their setups?
  12. PeterT
  13. RedMacGregor
    I agree - just fitted some 9.5 Nm springs supplied by K-Tech . They recommended these for my weight around 75 Kg without gear on. I was originally getting around 25mm static sag and 35mm loaded sag. With the new springs I'm getting 32mm static sag and 46mm loaded sag. This on the face of it looks like too much but if you read enough about these forks it isn't. What's most important is that you don't put too much preload on and stop the top out spring working - this is a no no. You are aiming to use all of the suspension without bottoming out (road use not track). If you use a tie strap on the fork leg you can see how much of the suspension you are actually using. The aim is to leave about 10-12mm below the tie. Once your sag is right you can start adjusting your compression and rebound.
    I'm using compression 4 out from full stiff and rebound 4.5 turns out from full stiff. I spotted some other settings in an American mag so might try these. For road work compression 5 turns from stiff & rebound 3.5 turns from stiff. For the track compression 3.75 from stiff & rebound 2.5 turns from stiff.
    The advice from a Aussie suspension guy on YouTube is to get the rebound correct first then sort out the compression. He also mentioned there is a relationship between adjusting the rebound and it affecting the compression and visa versa. So it looks like if you adjust just one you will have to adjust the other. This is because the rebound and compression shims are fitted either side of the piston - see the attached article on the differences between BPF and cartridge forks - http://www.efnetmoto.com/suspension.pdf
    There are plenty of videos on YouTube to demonstrate what you are looking for when setting rebound and compression - remember to warm up the forks with a short ride so that the oil is up to normal temperature before deciding on the settings.
    Even with all the fiddling they are miles better than the 2008 -2011 forks so stick with it.
    Steve.
  14. PeterT
    Suspension now spot on.
  15. stuart_g
    So what settings did you end up with?
  16. Kevin1
    Kevin1 Elite Member
    Must be a secret?
  17. PeterT
    These are what I am using. Had a great fast run out yesterday with this setting and it worked a treat with any road surfaces. Tyre pressure are 34 front and 38 rear.
  18. PeterT
    I have Bridgestone S20R tyres fitted which are super sticky
  19. RedMacGregor
    The front settings are very close to the track setting I noted in an American mag. Do you find you are out of your seat much on a bumpy road?
  20. PeterT
    No. I have dropped the rear preload by one setting, this gives a more compliant ride.
