suspension settings
Discussion in 'Mods, Upgrades, Accessories and Products' started by markie*mark0, Oct 6, 2014.
  1. markie*mark0
    markie*mark0 Active Member
    ive just got a fireblade after having suzuki's for a long time, not knowing much about the settings for the blade, has anyone got some good base settings from a suspension company?
    im around 16st fully kitted track use only.
  2. sps170373
  3. markie*mark0
    smashing mate!
    will give them ago, how much of the forks do you have showing in the top yoke? or are they flush?
  4. sps170373
    Flush as they came from the factory
  5. markie*mark0
    just thought i'd let you know settings were ace, bike felt stable and was on rails around the track!
    only issue i had was under heavy breaking the rear was leaving the ground and "snaking" around a bit, but i think it was a combination of a bit of air in the front brakes, resulting in me braking later / harder. and some very heavy late braking.
    i've fitted some brembo calipers and re-bled and will see how it is on track again, might be that i need to increase the height at the front or lower the rear slightly to stop the snaking but will see.
    cheers again
