suspension
Discussion in 'Maintenance' started by 010967djg, Sep 22, 2019.
  1. 010967djg
    010967djg Active Member
    Hi guys hope somebody can help me has anybody had there suspension set up on a rr8 for a 17 stone rider if so would they like to share the settings with me all info greatly appreciated
  2. dgr
    dgr Active Member
  3. Shutty
    Shutty Well-Known Member
    Just set the sag up via a video, as a guide 40mm frt and 30mm back
    Set the compression to stock and go from there. Getting the preload right will make a difference.
    Personally any more than that to get right its going to need a rear spring and frt fork springs to your weight and set up professionally
  4. Jez
    Jez Senior Member
    Once you have set the static basics sag etc just give any the adjusters half a turn one way (do note which one which way ) then decide is it better or worse, If worse go the other way half turn, This seems a very simplistic way but i have tuned mine in this way.I was hoping by now someone would have come up with a unit to fit to the bike that would say what needs adjusting.
    I have told my sons mate to make one as he does the robot software at our work but these yung uns take some motivating:mad::D
  5. roboticus
    roboticus Active Member
    they do one for mounting biking, there meant be good as well, u can hire them as there a few hundred quid
  6. Black & White
    Black & White Well-Known Member
    I've head of mounting goats....!
  7. LRJimmy
    LRJimmy Active Member
    Not that I want to drag this down, but go further North to the Aberdeen area and they're mounting sheep :eek::eek:
  8. Jez
    Jez Senior Member
    I shall have to look into this, I would have assumed someone would have come up with a high tech way of setting up your bike.
