Swollen brake fluid diaphragm
Discussion in 'Maintenance' started by TrackDayT5, Mar 28, 2016.
  1. TrackDayT5
    TrackDayT5 New Member
    Anyone ever come across this before ? Fluid needed topping up so I removed lid removed plastic and out popped the diaphragm.
    On trying to replace it's clear the rubber diaprham has swolen about 25% original size so now need to order new diaprham and will change full fluid on arrival.
    2009 Blade.
  2. sps170373
    Just looks like it needs pushing back into shape tbh! They distort the lower the fliud goes but should push back into shape
  3. TrackDayT5
    It's about 10mm wider in circumference than the fluid reservoir
  4. sps170373
    You ever taken off before? could be last owner has stuck a front master diaphragm in by mistake or to bodge it
  5. TrackDayT5
    I have never taken it off before when i bought the bike noticed the fluid was low so thats when i removed the cap to top it up, so with me needing a new diaphragm whats peoples views on the reservoir pipe mod?
    http://www.ebay.co.uk/itm/Genuine-H...503424?hash=item27cbb72ac0:g:ajoAAMXQ0pNQ~ER5
