Target AFR
Discussion in 'Mods, Upgrades, Accessories and Products' started by Moon, Apr 19, 2015.
  1. Moon
    Moon Active Member
    I'm a bit stuck on the target AFR's to go for when I get the Z-AFM on the bazzaz
    Can anyone give me an idea what I need to aim for? 13 - 13.2?
    I have seen some peoples maps online and they go for different targets at different throttle positions like 13.5 at say 20% but by the time they are at 80% they are going for 12.8
    Can anyone explain why they do this so I have a basic understanding of what's going on please
  2. Slick
    Slick Elite Member
    Essentially 12.8 generally provides the best throttle response and power where 13.2 the best economy without a detrimental effect on performance.
    So you would have 12.8 in the fun zones and leaner AFRs where you tend to cruise
  3. Moon
    Moon Active Member
    Ah so say, as I'm rolling on the throttle mid corner a 13.2 would be smooth, then as I sit up and open the throttle 12.8 would give me more power?
    Anyone have a AFR map I can have a look at?
  4. Slick
    Slick Elite Member
    #4 Slick, Apr 19, 2015
  5. carter
    carter New Member
    As a rule I used the compression ratio without any problems
  6. Cbrjay
    Cbrjay Well-Known Member
  7. carter
    carter New Member
    I just down loaded a generic map to start and used the auto tune from there... always been fine for me
  8. Moon
    Moon Active Member
    12.3?
  9. carter
    carter New Member
    Yep 12.3... had the same dilemma when I first got mine so rang a dyno place and he told me to use the compression ratio. Give a dyno place a ring if you have any doubts and I'm sure they'll point you in the right direction
  10. foenix
    foenix Active Member
    depends of the bike, every motor is different.
    Blade need to be a little rich to be powerful.under 13
