Tilt Switch Pisition
Discussion in 'Mods, Upgrades, Accessories and Products' started by ColinBR, Jan 23, 2015.
  1. ColinBR
    Hi guys
    Does anyone know where the tilt sensor is located in the nose cone? 2010 model
    Reason I ask is that I have removed the pair bottle and bracket from in there, and there was a relay/possibly the tilt sensor attached to it, and is now tucked away.
    Last thing I want is the bike cutting out if it is the tilt sensor.
    Thanks
    #1 ColinBR, Jan 23, 2015
  2. vic_ster51
    vic_ster51 Active Member
    tilt sensor is hid behind the headlights... front nose cone... remove headlights and you will see it! bit hard to disconnect it without removing it.. 2 long thin screws i think my memory and is protected abit too... ie not a easy pull a plug job! You prob just moved a relay of some sort!
  3. ColinBR
    Yea was thinking it was a relay.
    Thanks for that mate
  4. vic_ster51
    The tilt switch has a arrow... and word Up on it to... just so you can be certain colin
  5. Jimbo Vills
    Keep it upright, doesn't matter mate. Mines bolted to the clock bracket - no bother.
    If i got lean angles like SW it'd prob cut out though tbh ;)
    #5 Jimbo Vills, Jan 23, 2015
